waterin oil b
jjj
06-13-2005 20:07:24
we have b checked oil and milky and radiator down it does not smoke at all can coolant be coming from push rod tubes or maybe some one left lead washers off when over hauled had been overhauled before we got it thanks for help
John T
06-13-2005 20:34:40
 Re: waterin oil b in reply to jjj, 06-13-2005 20:07:24
If theres quite a bit of coolant getting into the oil via leaky pushrod tubes, you can find it by parking the tractor downhill with the valve covers off and see the coolant trickling down out of the pushrod tubes. Often if head gaskets or heads or blocks are cracked, it shows up as excess white smoke/steam out the exhaust and/or a lot of air bubbles rising up in the coolant as observed looking down in the radiator fill. If she not running hot or white steaming or smoking white out the stack, I would ceratainly take a look at those tubes.
John T
jjj
06-14-2005 10:11:40
 Re: waterin oil b in reply to John T, 06-13-2005 20:34:40
thanks john t we will check it tractor runs fine no smoke at all any time when radiator was low we filled with coolant ran it did get warm for a bit removed cap had coolant above core then reved engine cooled right down possible air in system but it has never smoked thanks for help what kind of job to replace tubes if bad
