gasket, John Deere D, RH govenor housing bearing
John R. Elko
06-18-2005 04:23:38
I need to replace the gasket on the right hand govenor shaft bearing housing on my 1937 John Deere D. can i take off the mag,coupler, and the bearing housing to change this gasket without having to take apart the the whole govenor? or is there something inside that needs work to get it apart? I also need a gasket. Deere doesn't carry it anymore. Part #D2577R
Glen in TX
06-18-2005 22:08:37
 Re: gasket, John Deere D, RH govenor housing beari in reply to John R. Elko, 06-18-2005 04:23:38
I think you will need the govenor off to change that one. Check with Greg or another dealer for those gaskets. I might have it too. You can make that gasket and then shim with thick and thin gaskets on the opposite side. An I&T manual and a parts catalog would be handy too.
