John Deere Model B (1952))
John Freborg
10-25-2003 08:51:58
I am restoring this model B JD. I need to know how to remove the steering shaft from the front worm gear area over theradiator. This is necessary to remove the metal top shroud so that I can prepare and paint Many thanks.
dave
10-25-2003 18:08:49
 Re: John Deere Model B (1952)) in reply to John Freborg, 10-25-2003 08:51:58
hiya yea u haft to remove stearing rod and choke linkage and shutter contreol rod if it has it . Thease hoods are fun to remove good luck. dave
F-I-T
10-25-2003 08:56:02
John:
On a '52 "B". also known as a late-styled, you would remove the steering wheel, and the front sheel letal medallion. Then remove the front bearing cap, and repain the shims. Then screw the steering shaft and it will thread forward. Then slide it out the front.
Frank
