1949 John Deer B
Jim Davis
06-22-2005 18:27:57
I am restoring my 1949 John Deere B tractor. I have the following questions:
1. What color should the axles for the rear wheels be painted? I like a medium or flat black for contrast, but want it to be authentic in any case.
2. What shade of black should the housings for the lights be? Again, I'm thinking probably medium black (not high gloss) or maybe even flat.
3. What color was the gas cap on the original model? I've seen red on some reproduction models. 4. Where can I purchase the original black seat and back rest?
Thanks.
Leroy
06-23-2005 04:47:50
 Re: 1949 John Deer B in reply to Jim Davis, 06-22-2005 18:27:57
All that I know is that when we got our 46 B, 49 B, 50 AR, none of them had been repainted and the 51 A, Not sure if repainted or not but don't think so the generators and lights were all green
ropot
06-23-2005 19:34:10
 Re: 1949 John Deer B in reply to Leroy, 06-23-2005 04:47:50
Some suggest using an automotive clearcoat on the axles after clening them up to prevent rust and keep the new metal look.
CLW
06-22-2005 19:41:22
The axles were not painted at the factory. Only overspray. Some paint them black and that looks good. Some don't paint them but put clearcoat on to stop rust. Gas caps are mostly painted red. Early unstyled all-fuel had red on small gas tank and green on large dist. tank. Medium black would work on lights and generator. "The Seat man" has an ad in GM with all kinds and colors. (605-432-6192) Says to leave message. Other places sell the cushions, but may not be original.
CLW
Jim Davis
06-23-2005 04:06:11
 Re: 1949 John Deer B in reply to CLW, 06-22-2005 19:41:22
Thanks, Larry.
Larry806
06-22-2005 19:38:24
The axels were " grease and rust" to be authentic The lights were green when it left the factory
fixerupper
06-22-2005 22:08:03
 Re: 1949 John Deer B in reply to Larry806, 06-22-2005 19:38:24
The black lights and generator didn"t come until the later numbered series.
CLW
06-23-2005 08:58:58
 Re: 1949 John Deer B in reply to fixerupper, 06-22-2005 22:08:03
If you will go back and look in the GREEN MAGAZINE or TWO-CYLINDER magazine at the "original pictures" of the lettered series tractor when they were introduced you will see they all have black lights and generators. Delco sent the (black) generators to Deere and were installed on the tractor AFTER the tractor was painted. The first time green generators appeared on Deere's was in the middle of the production run of the 20 series. The color of the generator was changed to green with the 1958 model 20 series and the dash was changed from green to black (thus the term BLACK DASH) at that time.
CLW
Pat Browning
06-23-2005 09:51:28
 Re: 1949 John Deer B in reply to CLW, 06-23-2005 08:58:58
Hi CLW -- I am looking for a reasonably authoriative answer to the question -- "What color rims (for the gauges) were used on the lettered series tractors?" Early on (unstyled), I recall the rims being Green. Did they go black when the styled models appeared (beginning with '39), or is it later that we see the balck rims on gauges?
CLW
06-23-2005 13:26:16
 Re: 1949 John Deer B in reply to Pat Browning, 06-23-2005 09:51:28
Pat, I read your question when you posted it a few days ago and I just don't know. I have seen all three colors you talked about but would not have a clue to what is correct or when.
CLW
Pat Browning
06-23-2005 15:01:25
 Re: 1949 John Deer B in reply to CLW, 06-23-2005 13:26:16
Thanks a bunch for coming back to me. Until recent times, I haven't thought much of it. A dear fellow up in San Marcos broached the question, and I took up the task to learn. 'Seems that may take a while. When I do learn. "I'll be back!"
CLW
06-22-2005 19:44:15
Larry, the lights and generator were black from the factory.
CLW
Walt in Jaxn Tn.
06-23-2005 21:50:45
 Re: 1949 John Deer B in reply to CLW, 06-22-2005 19:44:15
third party image
Photo?
Walt in Jaxn Tn.
06-23-2005 21:47:55
third party image
I remember an article in Green magazine or Two cylinder about the assembly line (early numbered series I think)that showed the tractors rolling on steel wheels thru the paint part of the line. I bought a 1946 long hood "A" in Texas recently that came from Kansas. It has the origional 1946 paint on it (except for the breather stack and battery covers) Three of the origional decals are still visible, the big dacal on the left side of the hood, the safety decal on the back of the pan seat and the patent decal just behind the flywheel near the top of the transmission case. All three of the lights are painted with what seems to be black gloss paint but not the cast iron bracket or the part of the light that clamps around the round pin, they are green. --Walt--
Pete/ME
06-24-2005 02:45:46
 Re: 1949 John Deer B in reply to Walt in Jaxn Tn., 06-23-2005 21:47:55
Walt, where did you find the battery covers. I'm hemming and hawing about buying a long hood because it's missing the covers. Thanks.
Walt in Jaxn Tn.
06-24-2005 05:33:10
 Re: 1949 John Deer B in reply to Pete/ME, 06-24-2005 02:45:46
They were on the tractor when I got it but I will ask the person I bought it from, they're a good quality set and fit very well. --Walt--
Pete/ME
06-25-2005 02:49:39
 Re: 1949 John Deer B in reply to Walt in Jaxn Tn., 06-24-2005 05:33:10
Thanks Walt.
