4010 I think you could plum one up the same way that JD recommended plumming up the tractor for the #35 loader if the tractor did not have remote hyd. All you need is an aftermarket open center hyd valve with its own pressure relief on it. I put an aftermarket valve on my loader and it works fine. Who knows maybe John Deere's middle initial initial was C for Cobbler because the books shows how to use pipe elbows and nipples to hook the #35b loader in the system. If you are interested, I could try to send you a picture out of my #35 loader book. No guarantees up front since I have a new scanner and havn't used it yet. Now I could be all wet on this ideaa for the detroit, but I am assuming that since you have basically the same touch o matic unit as the 420/430, somewhere on that buzzing motor there is a hydraulic pump that puts out about the same as a 420 or 430 - that may be the first thing to check into.
