B Carb question
Jim 52g
06-28-2005 12:20:27
my B requires a DLTX-34. will later B carb's work like the DLTX-67 or 73? If so what kind trouble will i run into? Thanks. PS my44B is missing the carb
Mike M
06-29-2005 07:41:50
 Re: B Carb question in reply to Jim 52g, 06-28-2005 12:20:27
The other B carbs. should work fine. Just don't stick an A carb. on as it will run but you will not be able to lean it enough to stop plug fouling.
Jim 52g
06-29-2005 17:42:00
 Re: B Carb question in reply to Mike M, 06-29-2005 07:41:50
Thanks guys thats the info i was looking for. just plan to use gas and needed a carb. now i can look at the other carbs if ever find one half way reasonable that i can rebuild myself.
Skyhawk Greg
06-29-2005 06:33:40
Jim - I am at work now, so this is only from memory. If you would like me to confirm which carbs will work on your tractor, just e-mail me at home at skyparkohio@sbcglobal.net. I have the John Deere books that state which carbs were to go on which tractors. In the meantime, if the DLTX 34 is indeed for all-fuel, the only major difference that I am aware of is that the 34 would have an economizer, and the later model of carb won't. If you run in the all-fuel mode, this is supposed to make a difference. If you only run gasoline, it won't. I have run my 1945 B with a late styled carb, and it worked fine.
Pat Browning
06-28-2005 13:54:08
I will bet you a quick call to Robert's Carb in upper Iowa will get you a great answer -- try 712-262-5311 and ask for Robert.
old
06-28-2005 13:22:20
Sorry wrong brand of B the carbs I have will not work. But the other things I siad should be right or at least close.
old
06-28-2005 13:20:41
Just a guess, but it sounds like you have an all fuel B. Also just another guess the other ones will probably work but I'm not really sure. I have a couple of them out in my shop but I have no idea how good or bad they might be.
