same parts???
joe e-tx
06-28-2005 19:33:39
put 2 rock shafts and 2 sets of bushings,and 5 sets of seals in our 2510, still leaks to this day. found out today jd house sold us our parts for a 3020.thay have wrong seiral number on file. are these the same ????.what are we doing wrong?. thanks for any comments
joe
joe e-tx
07-01-2005 05:05:06
 Re: same parts??? in reply to joe e-tx, 06-28-2005 19:33:39
sorry so long getting back (took mom to hospital).
will check with dealer on aftermarket parts.this was over a two year period.power shift tractor and hate loosing 5 gallons of fluid just to stack
round bales.
joe
Bobl1958
06-29-2005 08:34:05
Joe-I replaced the ones on my 3020. Like you said it leaked as bad or worse with new bushings, seals, and shaft from JD. I talked to the shop foreman at the local dealership, (where the partsman sold me the parts), and he said that they use aftermarket bushings that have an o ring in them. After replacing them again, never had any more problems. If you need I can probably get you some info on the aftermarket parts. Bob
thurlow
06-28-2005 19:40:33
I assume you're talking load control shaft?? Get some after-market bushings (the ones in the tractor housing)made with a machined place for o-rings. They may be available thru your dealer. They'll stop your leak; it's been my experience that the oil seals will ALWAYS leak, it's just a matter of when..... .
joe e-tx
06-28-2005 20:22:39
 Re: same parts??? in reply to thurlow, 06-28-2005 19:40:33
im talkin about were the 3 pt pivots at tractor housing at bottom .have jd seal installer and have tryed other things.now park tractor front down, and still add fluid.
thank you joe
mike1111
06-29-2005 04:53:46
 Re: same parts??? in reply to joe e-tx, 06-28-2005 20:22:39
I have put a few sets of load control seals and bushings in both 2510 and 3020, and they looked to be the same. did you have the load shaft checked? I have put two sets in the 2510 and the shaft was in question the last time, so when it needs seals again I will need a new shaft as well. The guy at the parts counter said two sets in 25 years wasnt to bad. ,, mike
