4555, 4755, 4955, ect.
jd jim A
07-03-2005 18:36:45
Are there any major differences in the 4555, 4755, 4955, 4560, 4760, 4960 vs. models like the 4250, 4450, 4650, 4850, 4255 and 4455? Did the 45, 47, and 49 have any weak points?
856 puller
07-04-2005 09:38:08
 Re: 4555, 4755, 4955, ect. in reply to jd jim A, 07-03-2005 18:36:45
we have 2 4955s 1 with 8000 the other with 6000 1 4450 with 8000 and a 4440 with 8000. the 49s have mfwd leaks and the rear axels have been redone and both engines the 4450 has never had anythig major. 4440 has had everything done. the 4555 is a big frame 4455 is a small frame all are good tractors
Silver Pig
07-04-2005 08:51:43
The 4555 is the small case tractor. Some of the early 15 speed Power Shifts had problems, but I would say that 99 per cent of these PIPs were performed on these tractors. If there are any current problems, they would stem from the fact of age/hours vs use and abuse, instead of some design flaw.
matthies
07-04-2005 07:25:59
One thing, don't be surprized if you see a low houred 60 series that's been overhauled. Deere had a problem with the piston rings that caused high oil consumption. These were the early models, but then they didn't make alot of them anyway. You also need to see if there was anything done with the aircleaner, there was a change with them do to the air filter getting plugged shortly in dusty conditions. I worked for a dealer and overhauled a couple with the ring problem and just heard of the air cleaner problem after a friends tractor ate to much dirt this spring. chris
