BOLT HUBS REMOVAL ON 4010
jim mall
02-27-2004 18:39:09
I WOULD LIKE SOME HELP ON HUB REMOVAL OFF AXLE ON MY 4010 JOHN DEERE HO DO THEY COME OFF.
Gman
02-29-2004 16:06:43
 Re: BOLT HUBS REMOVAL ON 4010 in reply to jim mall, 02-27-2004 18:39:09
Jim I think they are the same as a J.D.4000,three bolts on inside of hub and three on the outside plus two Jacking bolts remove the bolts(three) and turn jacking bolts in to push the tapered halve out the back,which you can break the halve if to much torque is put on it,soak with penatraring oil(blaster)a couple of days. If the wedge refuses to move get you a piece of pipe about the size of axle and cut top halve about mid ways pipe about 4 ins. back besure it will slip over axe and rest against the halve that goes out the back,I welded me a thick piece of metal on back of pipe to hammer against,you might have to heat with a torch if stuck very bad,when you get it apart besure to clean up halves and pinion gear gman
