Side wire plugs
Jim Nauert
07-29-2005 17:18:33
Can a spark plug that would fit a late A or B be had that is similar to a autolite 3077. Only in a 18mm plug.
P Browning
07-29-2005 19:05:27
 Re: Side wire plugs in reply to Jim Nauert, 07-29-2005 17:18:33
A site that may provide some promise is WWW.SPARKPLUG.COM
Duane Larson
07-29-2005 18:43:13
Jim,
Autolite does not make an extended nose 18mm plug. Champion makes the W89D 7/8-18 plug comparable to the Autolite 3077, and also makes the D89D 18-mm extended nose plug. AC-Delco used to make 18 and 18A plugs, which I think were extended nose 7/8 and 18mm also, but their recent catalogs just list it and provide no information. I've never seen them.
But before you try an extended nose plug in a late A or B, I would verify (using a screwdriver or something in the plug hole) that adequate clearance is available so the piston does not hit the nose.
