torque specs
37ar
08-11-2005 17:02:15
where can i find torque specs for a 37 a
Duane Larson
08-11-2005 18:31:27
 Re: torque specs in reply to 37ar, 08-11-2005 17:02:15
37ar,
Torque wrenches came into common use during WWII, and JD in their Field Service Bulletin 163 (Aug 1949) responded to requests for torque numbers with a limited table of values. What in particular do you need?
37ar
08-11-2005 19:15:22
 Re: torque specs in reply to Duane Larson, 08-11-2005 18:31:27
head bolts piston rods block to main case
Duane Larson
08-11-2005 20:06:32
 Re: torque specs in reply to 37ar, 08-11-2005 19:15:22
37ar,
For your 37 A,
Cylinder head studs 125 ft-lbs
Connecting rods 100
Cylinder to main case 125
