putting 4010 planetaries on a 4430
jeremy 4430
08-12-2005 23:18:09
I was told you could put the whole planetary assembly on a 4430 to gear it up. has anyone done this and what modifications need to be done... Thanks for any help....
donmyeil
08-13-2005 17:01:40
 Re: putting 4010 planetaries on a 4430 in reply to jeremy 4430, 08-12-2005 23:18:09
well it wont change the speed and they wont stand the hp either. They came out with 4020 gears and they wouldnt take it either. Deere changed the angle of the teeth and made them wider gears . The differentials wouldnt take it either untill they put the 4 spider gears in.
msb
08-13-2005 07:50:58
First of all, why do you want to speed a 4430 up?I am not sure it will speed anything up except money out of your wallet. If the tractor has a Sound Guard Body on it, the axle housings won't be drilled for the mounts.Brakes are different too.4010 axles are smaller.Why not just go to larger diameter tires and wheels?42" or 46" tires and wheels.
jeremy 4430
08-13-2005 17:39:34
 Re: putting 4010 planetaries on a 4430 in reply to msb, 08-13-2005 07:50:58
I was told that it would gear you up 10%. I am pulling hot farm and need to run faster that D4 which is 20.4 MPH.I am running 20.8 X 38 but can run 18.4 x 42's will that do anything for me. what about a 4640 gear set????
buickanddeere
08-16-2005 08:33:22
 Re: putting 4010 planetaries on a 4430 in reply to jeremy 4430, 08-13-2005 17:39:34
D4 down the track at 20.4 mph?Then you ask if 42" tires will help? Of course they will but..... .. This sounds like some joker with too much time on thier hands posting a "what if" question" A Hot Farm will be running at least 1-1/2 times factory rpms. You are not making 30+ mph wheel speed with a 4230's weight and a 404 engine. 203 RCI vs 217 RCI. That would be 107% faster or 21.6mph v.s. 20.4 mph .
jeremy123
08-19-2005 05:34:34
 Re: putting 4010 planetaries on a 4430 in reply to buickanddeere, 08-16-2005 08:33:22
we have a 466 motor and are running 2500 rpm
