1010 engine question
Chief
10-26-1999 19:50:25
I just purchased a nice 1010 gas and while I was adjusting the tappets I noticed that there is a plate about 3/8" between the block and the head. It seems odd that the corners are just square with the corners cut off and not rounded to match the head or the block. Question: Is this standard Deere or did someone add this for some reason. Thanks, Chief
Mike H
10-26-1999 19:58:48
 Re: 1010 engine question in reply to Chief, 10-26-1999 19:50:25
This engine has a special type of webbed together cylinder sleeve setup that is what the plate you see.All the sleeves are made on the plate
