axle length
1951G
08-22-2005 09:16:17
I was putting the rear wheels on my 35 B this weekend and got them each about 1" from the end of the axle. Later on I noticed the wheels weren't evenly spaced from the center of the tractor. After I took measurements on of both axles from end of axle housing to end of the axle, I got 2 different readings. One axle is 1 1/2 inch longer than the other. Could it be that someone installed a later axle on this tractor or is there something else that might need adjustment. I didn't think it came from the factory this way but wanted to check with you guys.
