4430 synco trans problems
Jerry Bucki
09-04-2005 11:31:02
I have a JD 4430 with a Synco-Range Trans this will not shift into reverse or high range it chokes the tractor off but in low, forward gears work fine and in tow all gears turn with a scew driver Can any one help figure this one out ??
Bob
09-04-2005 13:13:34
 Re: 4430 synco trans problems in reply to Jerry Bucki, 09-04-2005 11:31:02
It's stuck in low range because the low range pinion is welded to the topshaft, the shift fork is worn or broken, or something is amiss in the low shift collar/synchronizer.
You didn't happen to tow it, did you?
Jerry Bucki
09-04-2005 14:15:20
 Re: 4430 synco trans problems in reply to Bob, 09-04-2005 13:13:34
No it was not towed, I used this for side racking and after it would not go into reverse or high range, Should the syncro move on the shaft as far as the slide colars becouse this doesn't
