Are K181 and K241 interchangable on JD 110s?
Joel_in_Indiana
09-11-2005 10:50:09
I have an older square fender John Deere 110 that has an 8hp Kohler K181.
The K181 smokes, and I have another K241 I'd like to drop in its place instead of going through any rebuild process. Does anyone know if it possible to drop in a Kohler K241 from a newer square fender John Deere 110 into an older square fender John Deere 110 without any modifications?
Thanks in advance!
JD8020
09-12-2005 04:57:48
 Re: Are K181 and K241 interchangable on JD 110s? in reply to Joel_in_Indiana, 09-11-2005 10:50:09
I made that engine swap on a 110 years ago. On at least some years, it is necessary to modify the frame to get clearance for the flywheel housing. Roger
buickanddeere
09-11-2005 11:19:19
The parts book shows what as mixed and matched to make the 241 work.JD used the big block 10HP in the pan seat 112 for one year. 1-800-522-7448.
