3020 Synchro Towing Question
3020 towing Que
09-11-2005 13:25:43
Hello, I was wondering what kind of damage would happen if you do not put it in the towing position and tow it?
donmyeil
09-11-2005 14:03:12
 Re: 3020 Synchro Towing Question in reply to 3020 towing Question, 09-11-2005 13:25:43
If you dont put it in the tow position and go very far (probably over over 1000 ft) it will cost you abt $2000.00 as the reverse gear will weld itself to the top shaft and lock up the trans.
kdagenais
09-12-2005 05:13:32
 Re: 3020 Synchro Towing Question in reply to donmyeil, 09-11-2005 14:03:12
Thats what I was afraid was the outcome. The tractor just lost reverse after towing it and the transmission shaft was just rebuilt less than 200 hours ago (ouch!). The funny thing is this didn't happen till a little while after the tow because once they filled the tank it was used for a while with no issues & then all of the sudden absolutely no reverse.
