Jd A foot plate
Jim RI
09-18-2005 17:15:06
Hi, I am trying to replace the battery cable to the starter on my A and it looks like I need to remove the plate that your feet stand on (don't know correct name). It has two large screws that the top of them are the size of a quarter or larger. I have put penetrating oil on them and tried tapping them with a hammer but can't seem to get them loose. Is there a special tool I need, or how is the best way to remove them? I have been afraid to try any heat up to this point. Thanks, Jim
Maark
09-19-2005 14:26:39
 Re: Jd A foot plate in reply to Jim RI, 09-18-2005 17:15:06
Heat them up red hot and let them cool. They should spin right out.
Pete/ME
09-19-2005 02:28:53
I like "Aerokroil" for a penetrent, though a lot of guys like "P-B Blaster". "Aerokroil" seems to work wonders, used some on a steering wheel nut ('49 B), came back a week later and it came right off...the trick is time. If a bolt head is worn, I drive a metric socket on it.
960
09-18-2005 17:36:56
If you cannot remove them by chisel or driver method I weld a 3/4 inch nut on the head with 6011 rod let it cool and then remove with socket wrench.
Mike M
09-18-2005 17:32:41
An impact driver sometimes works. Many auto parts stores may have these.They have interchangeable bits and you can even use sockets on them.They are about 6" long and 1 1/2" around and you smack the end of it with a hammer.If that doesn't work I have used a punch and a hammer hitting the screw at the outer edge of the slot turning it to loosen it. this usually requires new screws as the old ones get pretty beat up.
