Late Styled A Question
1951G
10-11-2005 09:18:20
Can anyone tell me what serial number they started installing the creeper gears in the late styled As? I thought it was 1950 and extended through 1952, but wasn't sure of the exact serial number this started at. Also, did they make any other significant changes other than the square quadrant for the gearshift and doing away with the hi/lo shifter? I didn't think they modified the motor at this time but wasn't sure.
1951G
10-11-2005 17:35:06
 Re: Late Styled A Question in reply to 1951G, 10-11-2005 09:18:20
CLW,FIT
Thanks again for information.
1951G
10-11-2005 17:35:11
CLW,FIT
CLW
10-11-2005 12:10:03
At 648000 the single stick transmission came about. Also the block was changed from six studs and nuts where it attached to the main case to eight at the same time.
CLW
F-I-T
10-11-2005 12:38:52
 Re: Late Styled A Question in reply to CLW, 10-11-2005 12:10:03
They added a water pump to the late, late ones as well... #700200 and up.
Frank
