Model A
John Hatcher
10-15-2005 16:20:17
Could the problem I am having wiht the tractor puting out black smoke be an igniton timeing problem? I have tried adjusting the carberator but no matter how much ajust it it never sounds right at any point in adjustment before it will start to stall out.what shoud I do?
Jim-bobb
10-15-2005 22:09:28
 Re: Model A in reply to John Hatcher , 10-15-2005 16:20:17
How ya get it running right. I sure miss the 'putt putt' sound of the model A tractor I stupidly sold back in 1995.
F-I-T
10-15-2005 16:54:12
John:
What is the condition of the air breather? If you remove the oil cup and try it, does it run any better?
Frank
Maark
10-15-2005 16:51:17
No amount of twisting the needles will stop the black smoke if the float is bad or needle valve has some crud under it.
Ben48A
10-15-2005 18:10:46
 Re: Model A in reply to Maark, 10-15-2005 16:51:17
Also check the float pin is in all the way
