50 points
34gpa
10-28-2005 08:04:47
Does anyone have the part no. for points and condensor for a 50/60 or the 530/630 from Napa or o"reillys. Thank you
buickanddeere
10-29-2005 04:03:15
 forgot Re: 50 points in reply to 34gpa, 10-28-2005 08:04:47
Install a new dist bushing or all the tune ups in the world still won't make her run in top form.
buickanddeere
10-28-2005 17:32:30
Take those points and throw them into the trash. Get a Pertronics electronic conversion and one of thier high output 3.0 ohm coils if your tractor isn't bypass start. 1.5 ohm if it's a bypass tractor. Widen the plug gap up to 50 thou with Auto-Lite 3116 plugs, use solid core wires and enjoy.
DUP
10-28-2005 15:16:00
The Chevy points fit all DR distributors
Glen in TX
10-28-2005 11:06:14
Take your distributor number along and they should be able to fix you up.
DUP
10-28-2005 15:11:53
 Re: 50 points in reply to Glen in TX, 10-28-2005 11:06:14
Go to any parts house and ask for a set of points for a 235 in line 6 cylinder chevy. They work in any 2 cylinder JD. Just put a set in a 520. Cost about 5 or 6 dollars.
