49 A with X mag, back firing on starting.
Joe S.
11-15-2005 16:46:21
Wires not crossed. The mag has red rust under the cap. Gasket is now replaced. Points filed and gaped. Looking for direction as to what to use to clean off the red rust under the cap. Appears that the spark is flying around under the cap. Tractor worked fine one day the next back firing. Back fires when starting while choking. Plug are not wet. Resting at this time in a picked corn field.
Lee B
11-16-2005 00:34:39
 Re: 49 A with X mag, back firing on starting. in reply to Joe S., 11-15-2005 16:46:21
Red rust would be just that, iron rusting away inside there at an accelerated rate for some reason. It could be conductive so find the source and stop it first, then clean it up with a can of brake cleaner and an air hose.
The problem may also be a stuck dog on your advance. Does she go 'klack' when you turn the mag over slowly? If not, your dogs are stuck which means your timing is firing at 30 degrees BTDC - no wonder it backfires.
old
11-15-2005 17:48:30
My guess would be that you may have a cracked cap and or it got wet. You might type drying it out with WD-40 or something like that.
