Snowblower for a 2000 JD-445, Bet no one Knows!
2 Cylinder
11-20-2005 19:54:12
Been asking this question over and over, no one seems to know. What Model numbers should I be looking for, for a snowblower and snow blade.
tsmith1499
11-21-2005 10:56:10
 Re: Snowblower for a 2000 JD-445, Bet no one Knows in reply to 2 Cylinder, 11-20-2005 19:54:12
I know! Snowblower is a 47, and blade is a 54. If you have the hitch for one it will work on the other, so you don't have to buy 2 mounting kits. BTW, I work at a Deere dealer.. Good luck, Tom
Mike M
11-21-2005 10:25:40
If you ask your local dealer sales dept. they can find out. I'm sure it's going to have to be a fairly new model as that stuff doesn't interchange back many years by design that way you have to buy new implements when you upgrade tractors.
Bob
11-20-2005 21:16:58
I BELIEVE the Model "47" 2-stage snowblower (which has been around quite a while) can be mounted on that tractor with the proper lift adapter.
Also, the Model "54" blade, with the correct "Quick-tatch" adapter would fit
Glen in TX
11-20-2005 21:11:49
Go poke around and ask at www.weekendfreedommachines.org Or.... check with JD dealer for a listing of attachments.
