4020
1967jd
11-23-2005 05:50:26
Im having problems with my 4020D. After its hot (been used) it wont turn over. Ive put 2 new 550cca batteries on it. The starter doesnt have that much time on a rebuild, and I have every confidence in the rebuild, guy that did it is sharp. It wont even give a crank over any idea
Pete/ME
11-24-2005 02:53:46
 Re: 4020 in reply to 1967jd, 11-23-2005 05:50:26
I'll have to look at my O.M., but isn't there a lever that will disable some part of the hydraulics making it easier to turn over when starting? As to the starter, I'd just take it to the rebuild guy and have him load test it.
matthies
11-23-2005 11:31:55
Why was it rebuilt in the first place, and how do your cables look.
G/MAN
11-23-2005 07:22:47
I tend to agree with Mike. Sounds like there could be an issue with the starter, and when it gets heat-soaked, it's not capable of cranking the engine. Make sure you're getting full voltage to the starter positive and start terminals, etc.
Mike M
11-23-2005 07:11:42
Not saying this is the problem but even the best rebuilder can have problems beyond his control. He has to buy his parts somewhere and could of gotten some bad ones. I had a 3010 starter rebuilt once. Got a call from the owner a few weeks later said it won't start. Turns out the rebuilt armature went bad and you could hear it spinning on the shaft. The rebuilder and I both lost money on that one.
4010guy
11-23-2005 07:57:30
 Re: 4020 in reply to Mike M, 11-23-2005 07:11:42
sounds like your hyd pump is wear your drag is comming from try to release all preasher
G/MAN
11-23-2005 13:23:23
 Re: 4020 in reply to 4010guy, 11-23-2005 07:57:30
It should crank easier when warmed up, which is when he's having problems. Sounds like a starter issue. Possibly a field coil with high resistance that gets worse when hot.
1967jd
11-23-2005 11:08:14
i read on here somewhere to jerk the steering wheel while cranking to release some of the pressure??? is that for real?
G/MAN
11-23-2005 13:21:51
 Re: 4020 in reply to 1967jd, 11-23-2005 11:08:14
Cranking the steering wheel while cranking the engine takes the main hydraulic pump "out of stroke". Since the Deeres use a constant-pressure hydraulic system, the pump is always trying to maintain 2200 or so psi of pressure in the hydraulic system. That causes a drag on the engine and starter at startup. Cranking the wheel is kind of a band-aid for other problems, as they should crank just fine without cranking the wheel if everything is in good working order.
formula 409
11-23-2005 23:06:42
 Re: 4020 in reply to G/MAN, 11-23-2005 13:21:51
Actually Gman,turning the steering wheel causes the pump to go into stroke and when the wheel is turned,the pump is not building enough pressure to go out of stroke.Its in an almost free wheeling mode at that point.
IF the starter doesn't want to turn when hot,I would suspect the cables are corroded and corroded cables will break down and not flow all the current available fromthe batteries.Look for bulges in the cable insulation as a clue.
G/MAN
11-25-2005 07:25:02
 Re: 4020 in reply to formula 409, 11-23-2005 23:06:42
Yes, but seeing as how most people aren't familiar with exactly how the pump works in a Deere, it's easier to call it "destroking". In fact, Mother Deere refers to the screw-in and electric "destroking" valves, does she not?
4010guy
11-23-2005 11:25:26
yes it is for real to move the stearing wheel to release hyd pump preasher and allso take all preasher off remoats.right after i overhauled one of my 4010s years ago it would lock up like u said and i would let it sit for 15to30minits and it would turn over easy.never did find out why if it was from pisted drag or what but now it never bothers after 12to15 hundred hours on it.over hauled one this summer and works fine so maybe somebody els has an idee.
Jim in AK
11-23-2005 20:34:17
 Re: 4020 in reply to 4010guy, 11-23-2005 11:25:26
After I had my 4010 D rebuild 3 or 4 years ago I also had that same start problem. It went away after brake in. Guess I wasn't the only one.
Jim
