'50 model M John Deere
Jody
11-26-2005 09:42:28
Just bought my 1st antique tractor. I want to change all the fluids - oil, transmission and final drives - can someone tell me what to use (weights etc ) for all applications ? --- thank you !
FDBYRD
11-27-2005 20:23:57
 Re: '50 model M John Deere in reply to Jody, 11-26-2005 09:42:28
ROCKBASS IS RIGHT ABOUT ALL OF THE WTS. THE THING THAT WAS HARD TO BELIVE FOR ME AT FIRST WAS THE MOTOR OIL IN THE HYD. LIFT. I USE 30 WT. IN MINE WITH NO PROBLEMS.
Rockbasss
11-27-2005 02:26:15
I would have thought an Owner of a Model M would have given you an answer by now. So..... ..
I recently ask a question about oils for my JD '58 420u. What I got out of it was this
Steering Housing - GL1 140 or if it is empty use Corn Head Grease Final Drive - GL1 140 Transmission-Differential - GL1 140 Power Shaft - GL1 140 Crankcase - SAE 10W-30 non-detergent or 10w or 30w non-detergent motor oil (depending on season)
Touch-O-Matic - 10w non-detergent motor oil
I could only find GL1 90 when I was looking so that is what I used (what the owner's manual said to use)
I not sure if it would be the same for your tractor (other members are more experienced than me), but it is a place to start.
