Stuck Slant Dash A
jeffalex2
11-28-2005 02:57:54
Once freed up, do you always have to rebuild? Or has anyone ever been lucky enough that they run OK without too much smoke just being un-stuck? I've restored a couple Allis' and a Farmall...this is my 1st popper. Thanks!!
Ravgardner
11-28-2005 05:19:25
 Re: Stuck Slant Dash A in reply to jeffalex2, 11-28-2005 02:57:54
Rebuilding a stuck JD is not always necessary. Many times they will run without even taking the head off and honing the cylinders. Its always a crap shoot. I hope you have good luck with the JD.
Just a side note. We had an Allis combine with a four cylinder engine. Several times after setting between harvests that engine would set up. We always seemed get it going with a little be of work. But dad started finding barn space for it to keep it a under cover after a while.
