JD 50 clutch jumpy jerky
Jim Hummel
11-30-2005 14:04:28
I have the usual jumpy problem with this clutch. I have adjusted and re-adjusted. The plates are new when I restored it. I have completely disassembled and all parts look great. In adjusting I either have no engage or it jumps like heck. I was in Moline (JD Restoration Shop)last year, and they gave me some cupped washers or shims that they said would help. Where do they go? I put them under the castle nuts, and made no difference. Any help?? The tractor is not usable this way except in 1st or 2nd. Thanks
BushogPapa
11-30-2005 16:20:27
 Re: JD 50 clutch jumpy jerky in reply to Jim Hummel, 11-30-2005 14:04:28
Yea, my 520 is like that...!!
I take the outer cover and pressure plate off and paint an "X" right across the entier friction surface (on both sides) with spray Graphite..like you can get a "TSC" for helping grain slide.. I find that this lasts for up to a year and really does eliminate the "Jerks" in my 520.. I am sure it will help your "50".. Funny how the JD "B"'s don't seem to have this problem..!!!
Ron..
Jim Hummel
11-30-2005 17:09:07
 Re: JD 50 clutch jumpy jerky in reply to BushogPapa, 11-30-2005 16:20:27
Thats a great idea and meets all of the requirements. Quick, easy, and affordable. All this tractor does is parade, load and unload off the trailer and sit. Yes and I have a 49 B and the clutch is so sweet in it, and smooth. Go figure. Thanks !
Jim Hummel
11-30-2005 14:06:38
Oh yes, and I did try the slipping the clutch technique in a high gear and did not help either. Just forgot to put in initial thread.
Mel in SW Iowa
11-30-2005 17:25:23
 Re: JD 50 clutch jumpy jerky in reply to Jim Hummel, 11-30-2005 14:06:38
Find 3 (#8 hard)lockwashers to put under castle nuts (one on each), snug clean castle nuts down on clean deburred adjuster bolts until clutch lever pops over center, then use a beam style inch pound torque wrench to adjust to even settings.
Its always worked for me.
Good Luck,
Mel
Kmiller
12-01-2005 18:28:50
 Re: JD 50 clutch jumpy jerky in reply to Mel in SW Iowa, 11-30-2005 17:25:23
Also, when you adjust the clutch, just turn the castle nuts one slot at a time. You can get them pretty even by counting the threads showing above the nuts, if they're not even it will be jerky.
Jim Hummel
12-01-2005 19:23:54
 Re: JD 50 clutch jumpy jerky in reply to Kmiller, 12-01-2005 18:28:50
WELL...I tried the inch pound thing, and I tried the graphite thing, and even tried the lock nut thing, and it is just as bad as it ever was. Look for a show quality 50 with a jumpy clutch on Ebay soon. If 50's are notorious for jumpy clutches, I dont want one in my collection. Tired of working on it 10 hours for every hour of enjoyment... Thanks to all who tried to help.
Greasey Hand
12-02-2005 07:24:15
 Re: JD 50 clutch jumpy jerky in reply to Jim Hummel, 12-01-2005 19:23:54
Take the clutch all apart. There are floating disks way inside, You have to pull the seel like gear with the 2 threaded holes in it that is one the crank, it has a washer & a bolt holding it on.
you have to use a good puller. There are floating clutch rings in there 2 of them, They are broke I would say.
Jim Hummel
12-03-2005 08:41:03
 Re: JD 50 clutch jumpy jerky in reply to Greasey Hand, 12-02-2005 07:24:15
I am familiar with them and I think you may be correct. What have I got to lose, right? Thanks.
Greasey Hand
12-04-2005 09:04:16
 Re: JD 50 clutch jumpy jerky in reply to Jim Hummel, 12-03-2005 08:41:03
Jim When I do a clutch job I check it all over, Check the inside clutch disks, The adjusting bolts, Have had some with bad threads, Then they get replaced, When I put it all togeather I put new cuped washers under the adjusting nuts & with clutch lever forward I tork them all to the same tork & then adjust 1 notch at a time on the casulated nut.
Jim Hummel
12-04-2005 13:26:35
 Re: JD 50 clutch jumpy jerky in reply to Greasey Hand, 12-04-2005 09:04:16
Where do you get the cupped washers? I got my first set while in Moline. The JD restoration guys there just gave me a few to try. Where can I buy new ones now? Tx
