John Deere 4010 Diesel engine delimma
4010 puller
12-04-2005 17:51:06
Hey Guys:
I have a JD 4010 Diesel with an M&W kit. It appears the engine is junk (hole in block). I also have a JD 4430 engine that needs a little work. What can I do to the 4430 engine to make it naturally aspirated and run about 110 horse to farm with.
I"m imagining I need different pistons to raise the compression ratio. Is the 4020 piston kit the highest compression ratio you can get for a 404? What camshaft can I use to make her run a little better? Any cam out of a 466 or bigger? Is this beneficial for more power?
Thanks,
John
JDBert
12-05-2005 14:11:16
 Re: John Deere 4010 Diesel engine delimma in reply to 4010 puller, 12-04-2005 17:51:06
Are the M&W parts any good or are they shot?
superfarmer
12-04-2005 20:44:19
Why do you want to put it back to natural? A 4430 is only 125hp stock, I'd just leave it. Or if you think the rest of the tractor will only handle 110, just turn the fuel back a bit. A turbocharged motor will run alot more efficiently than a natural, so you'll save some fuel. If it were me I'd be throwing an intercooler on it too.....
Dave
4010 puller
12-05-2005 13:30:17
 Re: John Deere 4010 Diesel engine delimma in reply to superfarmer, 12-04-2005 20:44:19
Yea:
I agree on the power, but it seems the 4010/4020 clutches won"t handle it very well, been there before with a previous tractor.
John
superfarmer
12-06-2005 04:21:37
 Re: John Deere 4010 Diesel engine delimma in reply to 4010 puller, 12-05-2005 13:30:17
I see what you mean, but I'd think you'd be alot further ahead to keep the turbo and limit the fuel and it would have better efficiency. 125 is a bit much for that poor clutch, but 110 should be possible, just back the fuel limiting screw out about a half turn and it should be fine. Or, just leave the big power but never lug it down...;) That's what Kinze tells people to do with teh 855 he puts in the big 4WD's....
