2510 runs on
2510 guy
12-07-2005 16:56:44
have a 2510 gas. After it is shut off, it sounds like it is gonna quit, and then run backwards for a few seconds. Only after it is warmed up though, not when it is cold. Any ideas what is causing this?
Doug in IL
12-07-2005 17:21:47
 Re: 2510 runs on in reply to 2510 guy, 12-07-2005 16:56:44
There should be an electric shut off for the fuel needle screwed into the lower part of the carb. This is probably bad. Deere also sells a manual adjusting valve for these. Part number: AT23015. Idle speed could also be too high.
