JD 310B backhoe
1ST GEN.
12-07-2005 21:31:38
I have a 310B backhoe that runs and operates very good but when I use lower gears in the trans. it takes a second or 2 for the clutch to lock up, and when I use the high gears and let out off the clutch or use the shuttle shifter the clutch takes a little while to engage, and then it all of a sudden locks up and kills the motor, I have also changed the fluid and filters, what is wrong?
