Continued JD 420U cold start tests
Jim Bobb
12-12-2005 06:56:51
This morning in northern MI, it was -4F. The JD 420U with the 8-volt system started ok.
The starter was dragging a bit and the choke must be set just right. What I do is actually pull on the flexible choke cable to find that 'sweet spot' and it starts. Slowly 'hunt around' for best lower RPM once started.
Then, after a minute or so the engine picks up RPM with a few choke adjustments. After that 'minute', the engine is ready to make some power.
A small battery charger overnight would probally allow starting to -10F or perhaps even colder. Lower than -10F, I think I would stay inside my house.
Bottom line is the 420U is a good cold weather engine.
Mike M
12-12-2005 09:32:07
 Re: Continued JD 420U cold start tests in reply to Jim Bobb, 12-12-2005 06:56:51
Got a 4020 gas and it seems to prefer the cold temps. It seems to pop off quicker when cold than hot out.
Ken52M
12-12-2005 08:04:22
Jim,
I grew up on a 420. Hauled/spread munure 2X /day on Cent. WI dairy farm. We had a lean-to shed on No. side of barn where munure came out & tractor/spreader was kept. I do not ever remember a day when that tractor did not start. Even at - 30F. The 420 was later replaced by a 1020 special. I do remember times when the 1020 would not go. But that 1020 sure was a sweet ride. wish I had one today.
Ken B
