JD 730
2CYLINDERPOWER
12-29-2005 10:29:23
Is there a check valve in the bottom of the tank on a JD 730 Diesel that keeps the fuel from coming back down the return line from the pumps? thanks
Coastie Jim
12-29-2005 16:43:45
 Re: JD 730 in reply to 2CYLINDERPOWER, 12-29-2005 10:29:23
There is a fitting that threads into the top of the injection pump on the flywheel side and protrudes up thru the fuel injection compartment cover and the fuel tank return line connects to it and then goes to the tank. If you need one try Reniassance Tractor 360-748-0026 ask for Albert.
Mike M
12-29-2005 10:44:34
None in the tank. They did make a special fitting where the line goes down through the top pump cover that I think had one in it.
