JD 70, 2 cyl. Pony motor- Yr. 1956
John L Matt
01-07-2006 09:42:46
Wondering what the compression is supposed to be for the Pony engine? also would like to know if there is a starting point to adjust oil pressure for the Main engine on the adjuster? Thanks to all who answer.
The oleduke of Sag. Mi.
Blksmok
01-07-2006 10:39:48
 Re: JD 70, 2 cyl. Pony motor- Yr. 1956 in reply to John L Matt, 01-07-2006 09:42:46
John..... ..compression on pony should be balanced between all four cylinders and around 120 psi. I've seen pony engines start and run decent @ 90 psi, but they will be heavy smokers. Should adjust your oil pressure when engine is at operating temps and adjust it to be on "H" at fast idle. If it drops down into the "L" range at low idle the main bearings, oil pump,etc are probably worn.
