JD AR wiring diagram
1951G
01-09-2006 08:38:14
Could someone send me a wiring diagram that shows the wiring going to the solenoid, switch and battery? This is for a 1947 JD AR. Also, there's a magneto on the tractor.
Thanks.
Dave in SV
01-15-2006 05:31:01
 Re: JD AR wiring diagram in reply to 1951G, 01-09-2006 08:38:14
I have an e-file diagram for the A... will that be correct for an AR? If so, holler, and I will e-mail it to you.
Duane Larson
01-09-2006 12:56:15
1951G,
I have a Field Service Bulletin from 1952 which contains the wiring diagram for the A, AR, and AO (they are all the same). Send me an email if you want me to scan and send.
Glen in TX
01-09-2006 08:44:06
There isn't a wiring diagram for AR in the SM2029 Electrical manual. Just have to go by the parts catalog showing AR wiring harness and how the styled A is wired up. Unless someone has a service bulletin with a better wiring diagram.
