wico magnetos
Jim Glenister
01-09-2006 17:57:38
need a wiring diagram for wico magneto model xh1042 no spark at points thanks Jim
Glen in TX
01-09-2006 20:50:51
 Re: wico magnetos in reply to Jim Glenister, 01-09-2006 17:57:38
The short plain wire or short black wire on coil should be grounded on the coil clamp screw. The long black wire on coil goes to the points terminal. The condenser connects to points terminal. If you mag has the stop terminal it also connects with either a wire or strap to the points terminal. Make sure the strap isn't grounding it out. The spark plug wire in top of distributor cap tower goes to the # 1 cylinder on LH flywheel side and lower wire goes to # 2 RH cylinder. Make sure you clean the points well and or file them and set to .015" gap and check then for a good hot blue spark. You hear a good snap when the impulse trips also. If you need more help with it post back.
