Need help
4020 Man
01-27-2006 19:44:32
Need some help: just recently over hauled a gas 4020 all new pistons, sleeves, crank and ground the valves. I have run the tractor several hours since over haul, then last week end while driving the tractor down the road I began to see a large amount of white smoke coming out of the oil vent tube and tractor began missing and I'am getting a high pitched noise from engine now but cant tell from upper or lower end of engine. I'am new at tractor work and am looking for advice of what may be wrong. Thanks
Randy Varilek
01-29-2006 22:10:20
 Re: Need help in reply to 4020 Man, 01-27-2006 19:44:32
Hey 4020 man, If you did shell you new motor that is a bad deal. If you are interested, I have a complete running gas motor that I would be willing to get rid of. I'm in S.E. SD Let me know if you can use it. still in a 105 combine.
Greg_Ky
01-27-2006 21:07:33
Sounds like it spun a bearing
