Generator for a b
41JDb
02-03-2006 06:22:35
Im restoring a 41 B and I need a generator. It has been turned into 12v with the mag converted to a distributor with a coil, lights and starter.
So does anyone have a generator or know where I can buy one? Also I have only found 6v ones can they be converted? How much do they run and are they expensive to fix?
John T
02-03-2006 08:36:52
 Re: Generator for a b in reply to 41JDb, 02-03-2006 06:22:35
41, Try Ken Warner at Classic Generator in Texas, he can rebuild a 6 to a 12 Link
>Link Really, a 12 volt genny ought to be readily available from parts or salvage vendors located here or on other web sites.
I have used 6 volt gennys to charge 12 volts simply by using a 12 volt Voltage Regulator, but its NOT perfect or engineering correct and not any high rate of charge, just that it did work and charge with no problems.
John T
41JDb
02-03-2006 10:04:49
 Re: Generator for a b in reply to John T, 02-03-2006 08:36:52
Alright but I will have to find one and cant find one on this site and my local tractor junk yard has the most inflated prices ever. Please email me if you know where one can be found!~ Alex gerbel180@yahoo.com
