1936 JD D Pistons
John Hauck
02-03-2006 20:10:27
Looking for pistons for my 1936 JD D. Will most likely take .045 or .090 over to get the job done. None of the suppliers have aluminum pistons available. What do you all think about replacing with used cast iron pistons, if I can find a good pair?
alb1206
02-05-2006 14:06:14
 Re: 1936 JD D Pistons in reply to John Hauck, 02-03-2006 20:10:27
if you are interested i have 2 sets of .090 over pistons for your 36 D brand new in the box with wrist pins and rings.Will trade for front rockshaft for 530 john deere or a set of wrap around weights for the front of my 530 jd.
jhauck
02-03-2006 20:35:40
Seems one or two JD D piston makers in the US. Standard answer, including Hinrichs, is, "We don't know when the JD D pistons will be available." Too bad, because I am suffering from a couple slugged pistons in my 36 D. They had secured them with two countersunk bolts, one of which came undone and did considerable damage to #1 piston and the rocker tower. Made me want to cry when I saw what had happened. Had no idea the engine has been messed with when I bought it last Sep. Thanks for the info.
Glen in TX
02-03-2006 20:25:16
Used cast pistons will work fine if in good shape. Check the ring lands for wear and if worn too much can get OS width rings and turn grooves all the same. Look for good fitting pins also and then they can be fitted to your rods or put in new bushings to fit. Could always sleeve back to standard but getting hard to find a machine shop that can handle a D block and do the job right. You guys got me all curious now why everyone advertises those pistons but doesn't stock them. I'm going to have to call Monday just to see.
For oversize rings try these:
www.niagarapistonringworks.com
