D front steel with rubber
John T
10-27-2003 14:27:52
What size tire could I cut down to stretch the rubber over the rims on My '35 unstyled D on steel? I want to cut the sidewalls off of old 3 rib implement tires to use. Is there a size thats close? My rims are about 28" OD.
F-I-T
10-28-2003 06:03:31
 Re: D front steel with rubber in reply to John T, 10-27-2003 14:27:52
John:
I went to the Firestone Tire Data book online, and it lists a 5.50-16 as having an O.D. of 28", and 6.00-16's are 29".
You might want to have a look to determine what might suit you best.
Frank
JDBob
10-28-2003 05:14:58
John T.
I don't remember what size they were but a tire off of a Bobcat loader cut down and slide right over the front steel on our '51 D. Didn't have to splice it, just cut the side walls out, slip it over the rim (nice tight fit) then bolted it to the steel.
Someone might tell you what size the Bobcat uses,then you could hunt for a 3 rib that size.
I'm not much help on this but maybe it will at least give you an idea to chase for a while.
JDBob in MO
P.S. How's the little Harley Cart doing?
