870 Clutch Problem
Jenni
02-15-2006 17:34:39
My '94 JD 870 had a "sudden onset" loss of clutch.
I fired it up, and noticed that the rear PTO was slowly spinning...never does that. It was just free turning--you could easily stop it with your hand, but when you let go, it turned again.
When I went to put the tractor in gear, I couldn't.
Clutch all the way in, running smoothly, but it wouldn't go into gear. I pulled really hard and got in in reverse. It began moving in reverse, even though my foot still had the clutch fully depressed. I turned the key off to stop it.
A friend did some adjustment on the clutch, external to the case, and took out the free play.
But it still doesn't go into gear. However, if you just push the gear shifter forward, the tractor will creep forward. Stops soon as you take the pressure off the stick. Creep again when you apply pressure. It is not in gear--the shifter hasn't engaged...
Prior to this there was no slipping of the clutch, and there is no visible fluid or oil leaking around it.
Any ideas what happened? Does this sound like a hydraulic problem, or mechanical? thanks, Jenni
Jenni
02-26-2006 03:10:52
 Re: 870 Clutch Problem in reply to Jenni, 02-15-2006 17:34:39
I have tried everything and it hasn't worked...I actually was using the tractor to move the chickenhouse today...you'd think with all that using the brake, etc, it would have "unstuck" the clutch..
is it possible there's something else wrong?
is there something that could be disconnected? where would I check? I've already looked underneath (the obvious) and nothing unusual....
thanks
Mike M
02-15-2006 19:23:00
Your lucky your pto clutch isn't stuck like your drive clutch or else you would be minus an arm at the least !!!!! !!!!!
NEVER GRAB A RUNNING PTO !!!
Jenni
02-16-2006 07:12:38
 Re: 870 Clutch Problem in reply to Mike M, 02-15-2006 19:23:00
Thanks, Mike. I didn't, and I wouldn't. I had some friends over to help move a shed, and when I noticed it turning, I went to check that the PTO lever was in the off positon...it was turning very slowly, and a guy gingerly put his hand next it and stopped it without really grabbing it. He showed me it would stop with just a little pressure against the pto shaft...I gotta say though, his help with the shed was his braun, not his brains...but he had all his fingers after the tractor thing : )
Mike M
02-16-2006 09:09:48
 Re: 870 Clutch Problem in reply to Jenni, 02-16-2006 07:12:38
That always works better have someone else do it.
That's why Dick Cheaney had that guy flush his birds.
Jenni
02-27-2006 06:35:49
 Re: 870 Clutch Problem in reply to Mike M, 02-16-2006 09:09:48
I crack up every time I read this! :)
BlaineM
02-15-2006 18:19:28
HI Jenni,
Same thing happen to my 870. Start the tractor-lock the brakes together-push the clutch all the way down and hold-put the tractor in gear,all the way in,-give it a little throttle and put all the pressure you can on the brakes.This should break the clutch lose.It worked for me. Let us know if you need more help. Have fun Blaine
BlaineM
02-20-2006 12:54:01
 Re: 870 Clutch Problem in reply to BlaineM, 02-15-2006 18:19:28
Hi Jenni,
Put the tractor in low range-Start the tractor-clutch depressed-put it in 2nd or 3rd-I don't think,it makes any difference if it is in 2WD or 4WD-get the tractor moving-give it as much throttle as you are comfortable with-THAN apply the brakes gradually,not to much that you kill the engine.Keep trying-I don't think you are going to break anything.Let me know what happens. Blaine
Jenni
02-20-2006 11:52:14
Hey Blaine, thanks for the suggestion.
I can't seem to make it work...I've tried in all 3 speeds (I can only get the shifter into reverse and 1st gears), in 2WD and 4WD, and on dirt and out on the pavement...I can't get the shifter into gear if the brakes are on too tightly, and if I get it into gear, then go full speed and stomp on the brakes-- quickly or gradually, the tractor dies.
I haven't had enough strength to push the shifter into gear when the tractor is at standstill, idling low speed, clutch depressed, brakes pedal down hard as I can.
Should I try harder? I was afraid to break something, since the shifter is so resistant to go into gear with the brakes depressed. Or is this what it takes to break the clutch loose? When I try to shove the shifter a little harder, i rise out of the seat, and the throttle starts to kill...
Thanks, Jenni
Jenni
02-27-2006 06:41:19
 Re: 870 Clutch Problem in reply to Jenni , 02-20-2006 11:52:14
Blaine,
I used the tractor in low gear to help move another shed this weekend...No amount of braking ever broke the clutch loose.
I ran it in 1st and 2nd speeds, using only first gear and reverse.(shifter won't go into higher gears)
Any other ideas? I really need to use the PTO, but of course I can't until the clutch is working!
