model 40 oil pressure
40 joe
03-07-2006 18:06:10
after changing rings on a model 40 I seem to of lost oil pressureI have around 10 psi cold and drops off from that it was around 30psi , have changed pumps around and gauges same pump and gauge works fine on another engine.the circulation of oil is there when you pull a gauge or plug out it seem like the oil is passing back around the pump instead off pressuring up. all the bearing look fine ,please help!!!
40joe
03-08-2006 06:25:11
 Re: model 40 oil pressure in reply to 40 joe, 03-07-2006 18:06:10
No I did not change the rod bearing they were standard and in good shape, I marked and match every thing back up,used white greese on them
ET
03-08-2006 04:51:59
Did you put in new rod bearings? If you did, could you have put standards back in where there once was .010 undersize.
Henry M
03-08-2006 05:25:13
 Re: model 40 oil pressure in reply to ET, 03-08-2006 04:51:59
ET
I thought about that but hesitated to say something. I saw that done once and don't even want to say who's tractor it was that the ace mechanic miked for replacement inserts.
