730 tranny/rear end check plug
4010 puller
03-23-2006 07:48:44
Hey guys:
I"m still having trouble finding the check plug to see how full they are with oil. Can someone describe it to me a little better?
Thanks
4010 puller
03-24-2006 19:30:11
 Re: 730 tranny/rear end check plug in reply to 4010 puller, 03-23-2006 07:48:44
Boys:
I still ( for the life of me)cannot find the check plug. Ive searched all over to the right of the flywheel cover to the axle housing but cannot see anything. The only thing I see to the right of the flywheel cover is a cover with 3 or 4 bolts holding it on to the engine but doubt that it"s anything to do with what I need.
Thanks!
JD man in SD
03-23-2006 16:48:40
it is 3/8s cap screw takes 9/16 wrench it should have alem. washer on it lol Kent
Dave-Ia
03-23-2006 15:23:47
It is a small cap screw about a foot behind the back edge of the flywheel cover. It takes either a 1/2 or 9/16 inch wrench. The 4 o'clock position is probably about right.
Maark
03-23-2006 09:13:27
On the rear cover at about the 4 o'clock position there is a large plug.It is the one closes to the rear axle. Check your tranny there. The pto will be a smaller one probably on top of the pto assy.
