Compression Results
41Jdb
03-23-2006 20:09:30
Adjusted my tappets and tractor is running better.(1941 B) It sat for 10 years before i got it running this winter. I gave it a compression test and it gave 80 psi in both cylinders. Is this good compression for a b? What does this tell me about my valves and ring conditions? Thanks Al
jasper t
03-24-2006 07:42:14
 Re: Compression Results in reply to 41Jdb, 03-23-2006 20:09:30
just assuming here. the IT manual says 110psi for gas. i would think that if it had gas pistons. if it had all-fuel pistons i'd think the psi be lower. burning gas in an all-fuel engine doesn't make it a gas engine. let me know if I'm wrong just assuming here
Mike M
03-24-2006 05:24:16
Your tractor is an all -fuel model and I think the pressure listed for them is only around 75 psi so you should be in good shape !
41JDb
03-24-2006 05:46:21
 Need A Manifold in reply to Mike M, 03-24-2006 05:24:16
Its an all fuel tractor that is running on gas so looks like we are good. Looks like Im starting to get a manifold leak and priced out my manifold from a few sources and they are all around $230. There gas ones are around 120. Since I am only running on gas can I get the gas manifold or since I have an all fuel tractor do I have to get the all fuel one. Thanks Al
Mike M
03-24-2006 07:26:53
 Re: Need A Manifold in reply to 41JDb, 03-24-2006 05:46:21
You might just keep an eye out on ebay to see what shows up ?
I put a gas one for a later model on a 1945 B I'd have to look ,but I think I had to rework the exhaust flange ? My intake was kicked out alittle makeing the air hose connection off a bit.
RedJD
03-23-2006 21:28:26
I&T manual says 110 psi for a B on gas.You should be ok unless your going to pull this tractor.You can squirt some oil into the sparkplug hole and recheck compression. The oil will form a seal around the rings for a few minutes, if the psi goes up you will know the valves are doing their job.
