Deere A , oil capacities and weight question.
1944_A-aron
03-26-2006 21:02:07
I have a 1944 A and need to know how much oil to pour into the rearend. I read on here that a 140wt oil was ok for a "southern tractor" so here in NC I guess that is good enough. I currently have on the tractor a power-lift unit but recently purchased a power-trol unit off a parts tractor nearby. Should this be a potentially easy swap and what wt and how much oil should I use in either of these units? Thanks for the help. Aaron
Maark
03-27-2006 12:18:10
 Re: Deere A , oil capacities and weight question. in reply to 1944_A-aron, 03-26-2006 21:02:07
All you need to change from powerlift to powertrol is the box on the housing. No need to remove the complete rear cover. The owners manual says to use 30 wt. oil. But many use the same hydraulic oil as the rest of their equiptment.
