A head
Jim 52 G
04-04-2006 14:40:53
still no parts book yet. I need to know if a 47-52A head will work on a 45A. machine shop found cracks and I found a good buy on the later head. we are going to check castings numbers but won't be able to do that in a couple of days. thanks Jimmy
Lynard
04-04-2006 17:41:07
 Re: A head in reply to Jim 52 G, 04-04-2006 14:40:53
Jim 52 G Yes it will. The head is .200 inch shorter which is in the combustion chamber. Will raise compression and probably need to shorten push rods. Some of the very late ones use a different style oil feed that goes under center head bolt and provides oil to rocker arms. Lynn
