sand blaster
Jim 52G
04-05-2006 14:59:56
I have the blasting cabinet without the dust collector. sand make to much dust. the local dealer has alum. oxide, garnett, and glass beads. does anyone know which would make the least amount of dust? Thanks Jimmy
johns48b
04-06-2006 18:23:34
 Re: sand blaster in reply to Jim 52G, 04-05-2006 14:59:56
i put a five gallon bucket stuffed full of old burlap bags in line between my shop vac and my booth and it helped save the shop vac filter. just bore the right diameter holes in the bucket and push pipes in. off set the holes so that the air has to be sucked through the bags to get to shop vac.
jubilee johnny
04-06-2006 08:02:58
My grandfather got black lung disease from breathing coal dust years before we knew what we know now about breathing stuff like paint additives, and all sorts of other stuff. I would recommend you try to find a correct vacuum/filter/dust collection/ evacuation system for your health. Another place you could try would be www.skatblast.com . They also sell lots of different kinds of abrasives from glass beads, walnut shells, aluminum oxide, even plastic.
Glen in TX
04-05-2006 16:34:01
Glass beads will make less dust and aluminum oxide a bit more than the glass beads. Just use some mesh filter or piece of scotchbrite for a inlet air filter on the blast cabinet and use a regular old shop vac for dust removal.
tptools.com
blast-it-all.com
marcousa.com
brutmfg.com
