plow for 730D
mjbrown
04-08-2006 15:28:49
I found a f145 4x16 semi mount plow nearby and wondered if my 730D will pull it. I need another plow like a hole in the head but I thought they would look good together at plow days etc. Any serious plowing I do with a 4230 and don't do much of that anymore. The 730 is a strong runner, it dynoed at 73hp turned up.
It also has front and wheel weights.
Thanks
JLG
04-09-2006 14:55:46
 Re: plow for 730D in reply to mjbrown, 04-08-2006 15:28:49
I pulled a 4- 16" semimount with a 730 diesel. Was in 2nd gear, but the tractor has since been overhauled and has a bit more power. I had 400 lbs out front and could've used a few more though.
55 50
04-09-2006 11:21:54
It makes a lot of difference as to what type of soil you have and your depth of plowing. In ND, we pulled either 5-14s, or 4-16s, pull type plows with "R"s, 5 to 6 inches deep.
mjbrown
04-09-2006 06:51:31
Thanks for the replies and info. It's available for $600.
msb
04-08-2006 20:42:10
You will need a special hitch adapter since the 730 is a top link sensing system.They weren't terribly successful however.Its pretty hard to get the correct tumbling action on the center link with the adapter. You would be better off with a fully mounted plow or a pull type.I had a 5-14 pull type for several years ,then traded it for a 4-16 pull type.
I set my 730 at 65 horsepower,if I remember right.I set the high idle at 1300 RPM, which is about as high as the lead governor weights will go before being thrown off.Yep,I did that once.
jddriver
04-08-2006 18:30:47
We pull a 4-16 roll-over plow fully mounted with ours Steve
DSK
04-08-2006 17:23:12
Although 3-16's would be a better choice for your 730, it should handle the 4-16's OK in light to medium soil. The F145H was reducable, in fact there is even directions how to do so in the operators manual. A semi-mounted plow also pulls somewhat easier than a pull type, but you will need quite a bit of weight on the front of the tractor.
