hyd. valve leak
3010JD
04-09-2006 18:20:57
I have a single remote valve on my 3010. Have oil leaking from bottom of the valve. I hate oil leaks. Book says that if you had a second valve it would bolt under the first one. Question is; are there o-rings under the plate I have on my single valve that can be replaced? The book does not show? Just wanted to know before I take it apart. My guess is there are o-rings that need to be replaced. thanks
msb
04-09-2006 19:40:27
 Re: hyd. valve leak in reply to 3010JD, 04-09-2006 18:20:57
Actually they are square packings.Part # R 26149.You will need two of them and I use heavy wheel bearing grease to hold them in place while I replace the bottom cover.
Bob
04-09-2006 19:06:16
Yes, there are "O" rings between the valve and the plate.
