Jeremy, that popping back trough the carb is usually a sign of plugged passages in the carb.. ~In your case seeing as it ran good one day & not the next could also mean a fouled [or partially fouled] spark plug. ~About the first thing to do is try pulling the choke partially back on,, if that makes it run closer to normal you have a carb problem, or fuel flow problem.. ~If the choke doesn’t help you, then more than likely have a spark plug, ignition, or valve problem. ~If you suspect a carb problem, first run a fuel flow test…To do that ,,, open the carb’s lower drain cock, then see if you are getting a pencil sized stream of fuel flowing for AT LEAST 30 seconds, if not, suspect a plugged carb strainer, or tank strainer, or the possibility of a fuel shut off valve not being fully open or even plugged. If it has a 3-way valve that is a very common problem area so make sure it is open completely. ~If your fuel flow is good per the above then suspect a plugged passage inside the carb. If that is that case you might first try a farmer’s carb overhaul.. How to do that you ask?… Just remove the carb’s intake elbow, then start the engine & run at fast idle, then place your hand over the carb’s intake until the engine almost stalls. Do that a few times as that will pull gasoline back through the internal carb passages & air bleeds. In some cases if the carb isn’t plugged too bad that will clear the internal passages. [This usually only works on a freshly plugged carb & not an old rusted up one]. ~If the carb isn’t the problem then you might have a burnt or tight intake valve.. Do a compression test & check the valve lash.. ~Your problem could just be as easy as a fouled spark plug so if the choke partially back on doesn’t help, try new spark plugs to eliminate that right off.. ~You could have a verity of other problems from cracked plug wires to water in the distributor cap, to bad gasoline, to a weak ignition coil, to?. ~If you can’t get that carb to operate correctly & using the choke still makes it run better, post back [or E-Mail] & I will send you a carb diagram showing the passages that need attention & cleaning.. It isn’t rocket science but is difficult if you don’t know what passage & holes need cleaning.. ~If the above doesn't help, or at least doesn’t get you on the right track to finding the problem just post back with some more & added information on the above & we’ll help you track your problem down.. JDClooney@aol.com
