JD400 Hydraulic Oil Refill Procedure
John Still
04-13-2006 10:43:18
I don't have access to the manuals. It has a backhoe and a loader on it. Serial number ends with 747 under the seat and 311 on the engine. The hydraulic pump is the 8 cylinder model. Should the oil level be checked with the everything tucked in ( loader bucket and stabilizers. Or should they all be extened as far as they can go? ( bucket in the air, backhoe stratched out on the ground, and the stabilizers out) Thank you in adavance for any information.
Glen in TX
04-13-2006 12:44:08
 Re: JD400 Hydraulic Oil Refill Procedure in reply to John Still, 04-13-2006 10:43:18
You would check it with the cylinders pulled in and front loader down. JD sells manuals for 400 from the industrial site.
John Still
04-13-2006 16:22:58
 Re: JD400 Hydraulic Oil Refill Procedure in reply to Glen in TX, 04-13-2006 12:44:08
It"s much appreciated that you shared your knowledge. Thank you
